Hey guys so I just got a La Croix DSS60. FUGGING LOVE IT.
However, I kinda want a thane wheel option. Does anyone know if Trampa super star’s are the same bolt patter as MBS Rockstar? They look like they should be, but looking to confirm before I buy anything. If they are in theory I can make the La Criox wheel gears work with the MBS Rockstar hubs.
I would prefer abec 107’s but I can’t run Abec 107’s on MBS trucks right? like the bearing’s abec’s used are way smaller and wont fit MBS tucks?
MBS has different hubs, so you need to be specific. Gummies are designed to fit our hubs perfectly, preventing any slip. The hub profiles differ from manufacturer to manufacturer! We never tried to fit them to any other hub.
Maybe. I would be a bit concerned with the 5mm width considering most bearings are 8mm. You might need a spacer to make the wheel wide enough that the threads tighten the bearings. You could try and report back
