Hi Do you think the trampa mounts work on the evolve truck ? I think to get 2 evolve front truck to used on my flat deck and used the motor mounts from trampa
Thank you
Thank you
no they do not.
May I ask what is your reason for wanting to use the evolve trucks?
Bc i need some truck go on flat deck and I can use AT WHEEL
What motor mounts work on it
I will not use the back truck only the front truck I was thinking I can use the same thing to the motor mounts from trampa
no you can’t. there is not a single motor mount for the front evolve truck.
Check out @psychotiller website, he’s been putting AT wheels on standard decks since the dawn of esk8
