Only Used for a couple rides before switching to another kv setup for build.
Works great almost new expect one of wires has a spot exposed but can just wrap over with heat shrink or tape, doe not effect performance at all.
Spec.
Battery: 9~10 Cell /33.3~37V
RPM: 245kv
Max current: 60A
No load current: 10V/1.45A
Current capacity: 78A/15sec
Internal resistance: 0.03 ohm
Weight: 649g (not including connectors)
Diameter of shaft: 8mm
Dimensions: 89x64mm
Whats the bottom line? I build boards for people who in most casses can’t afford e-boards. It’s not just about
the money it’s about when we were little and wanted something with a passion but parents couldn’t afford it. Not trying to pull on your heart strings just giving you a little background on what I do. If you’ed like to see what I do you can go to www.kickedoutskateboards.com to see I’m not full of **it. lol, Hope to hear from you soon and thank you!
