Hi everyone,
I am looking to part ways with 2 Panteras, These are very diy oriented boards and I don’t have time for them, So just sitting there.
I have not long just bought 2 brand new 1.2kwh battery packs for them probably cycled less than 10 times, I have converted 1 of them to accomodate the new bigger pack, but the other 1 is currently dismantled and waiting conversion.
1 of 6374 motors is dead, but just needs dismantling and rewiring.
Spares include,
2 new drive shafts + pins 2 polygon wheel nuts, 8 + motor pulleys 20 + drive belts 20 + spare tyres Complete new set of fixings (bolts, ball n socket joints, grub screws, etc) 4 x nylon rims (spare wheels) A arms, left, right, top and bottom 1 x new pantera grip tape 4+ new charging sockets 2x 5a chargers 2x 10a chargers These boards are fitted with the towing hitch,
1 of them has recently had a new esc so doesn’t display the 1000+ miles it’s done, The other one only done about 700 miles
I have also made some of my own modifications for example,
-The A arms are mounted with metal bushings, which after 200 miles start rattling, I swapped these out for my own custom p66 nylon bushings and done over 1000 miles, and still going strong.
- inside the drive shaft /cv joint they use cast plastic ends for the drive pins, which they openly declare as consumables, but the panteras are too powerful and destroy these after every other ride, so I experimented a couple of the drive shafts using p66 nylon spacers instead (never had to replace them again) but I havn’t got round to fitting the rest.
- I have installed external anti spark xt90 connectors in case you want to use a hobby charger to charge up or just want to kill power to the board
Oh and the headlights on the white 1 broke But i’ve installed a 5v rail so different ones can be fitted which I will supply.
I am looking for £4k for both boards and all spares.
I can also deliver 100+ miles from Lincoln for the cost of fuel
Thanks for reading.
Please remember these are Used, so will have wear and tear on them
