Used but working Bestech BMS for 12s Li-ion cells.
Also includes 80A continuous current E-switch.
Has original and unused balance cables.
Note: Discoloration on the back is caused by heat from balance resistors.
More info and full specs here:
http://www.bestechpower.com/444v12spcmbmspcbforli-ionli-polymerbatterypack/PCM-D223V1.html
£40 + Postage (or colection from wiltshire)
Did you just test it the one time? That’s a fair amount of discoloration
No this is the BMS from my main main board and was used daily for all of last summer.
Im selling it cause im building a new board with the unity (integrated power switch) so have brought a smaller charge only bms.
That’s a sick enclosure.
May I ask where you got it?
I Made it, took long time on a cheep <£250 CNC but i guess times not a problem when its doing the work for you. Probably still quicker and stronger than printing it.
moon
May 28, 2019, 10:35pm
7
Ill take the JST connector ahaha
Not sure if I want to break this build yet. I guess if someone else wants the other parts I could split it.
FETs anyone? Maybe just a heat sync?
moon
May 29, 2019, 1:31pm
9
Haha just kidding really. The JST connector is like the only thing stopping my build
