I’ve had my GT for about a month now and I’ve been loving it so far. However I’ve run into a couple mechanical issues over the last week. The first is the CF board made a loud crack noise when riding normally. I later found out that the board has a small split in it shown here…
The second issue is that somehow, probably due to too loose of a belt, the belt skipped over the pulley lip and started running against the motor cover until it cut through. I stopped within a second of noticing this but it still cut through the motor cover. I had the belt loose to avoid tension and heat and it never skipped, but I’m probably going to tighten up my belt and forego motor covers after this.
