@ElskerShadow : I not worrying, he already confirmed my order is processing
But thatās the last part i need to finish my build with @Riako
I have few questions :
When did you placed your order and how long it took to receive it ?
What do you think about this remote (vs. a GT2B, R1/R2, ā¦)
@Wajdi : Still no emails even with the other emailā¦ Maybe your system is not working
I also saw you might plan to change the design, will it be possible to order just the printed box ?
Damn I wish @Wajdi could design a second version of his remote with two separate buttons like this.
That Evolve R2 is great ā¦and feels great. Having two buttons was a very clever idea.
@Zigm4 I tried to send you the order confirmation manually right now, let me know if you still donāt receive it.
Iām not changing the design any time soon, perhaps in the future I will work on an additional version.
I agree w thisā¦ the concept of having a ādashboardā is cool but on a board (moreso than on a bike or a car) you really need all your focus on the road so you can react to what is happening.The data available isnāt really helpful unless you are prototyping/testing electronics. I passed on a coulometer for this reason.
I'm so excited for this combo! I purchased the remote and the receiver off your website on Feb 26 Using paypal.
Do you have an ETA for future remotes? Order ES-252. This remote is very desirable for me, as my current setup is a bit too touchy.
I have dual 80MM 6kw motors running 12s. need a better controller. Mostly for brake ramp and initial startup smoothing. I will have questions too on how to hook to dual VESC and also dual BL-Control 9120 150A Escās.
I just realized i may need two receivers for dual motor. Is this the case? can you invoice me for another one through paypal or something so i can make sure i have what i need? Thanks ā _*
I got my remote today so I immediately set everything else aside and got to work on swapping remotes thinking I could knock it out quick and go for a short ride. I was wrong and I hate software sometimes. So I have tried Ackmaniakās V3.10, stock V3.35, stock V3.31 and stock V3.29 firmwares. I realize some of the firmware versions arenāt supported but I was just giving it all I had available at the time.I have the TX and RX bound with green lights on both plus I have telemetry coming through just fine on the remote. I have the baud rate set and Iāve tried setting it to UART as well as Nunchuck (not nrf) and selected current in the nunchuck menu. The remote button up front is set to cruise. However I am unable to get any throttle response from the motors and I canāt see any indications of stick movement in the VESC Tool with any of the firmware versions I have available to me. Unfortunately I can not find any past releases of the VESC Tool for Windows other than what I have previously downloaded. My other remote works if I set it to PPM and reconnect the servo connector so the other settings seem fine. I may be skipping something simple out of frustration but Iāve done everything I can think of and Iām not getting anywhere. Does anyone have any ideas or know what I may be overlooking?
Canāt really help but the struggle can be hard for this remote.
I recieved mine 2 month ago never used it because I could never bind it. Apparently @Wajdi sent me a new RX to try but been waiting for week.
Since early January iām the happy owner of a 170 ā¬ brick remote
@Dizzee I have been looking into this for the past few days, and I found the problem. I forked the bldc source code and applied necessary changes to get this working again. I will release a modified FW 3.34 tonight that should get cruise control, reverse, and nunchuck controls back on UART.
I can understand your frustration. Itās a lot of money to have sitting around. To Wajdiās credit heās taken responsibility for the original receivers and he seems be doing what he can to get it working as intended. Iām more frustrated with the state of the VESC project. There is no reason given for the changes effecting products that do nothing but add value. For me the fact that thereās no repository containing past releases of software and firmware is beyond frustrating. All I could find was a forked GitHub project containing previous releases for MAC OS. I donāt want to muddy the thread with VESC frustration. I just wanted to state what effects this project directly though. Especially if a specific range of firmware is necessary for the time being.
For those that need it and can make use of it, hereās a link to the previous releases of VESC Tool for MAC OS. MAC VESC Tool Releases
I just managed to have the controls compatibility issue fixed. The modified version is FW 3.35, thats the latest release, I made changes to fix nunchuck compatibility issues with the Photon receiver.
You can download the FW from my GitHub here https://github.com/wajdib/bldc/tree/master/build_all
Make sure to choose the correct hardware version, and the default FW available.
For this you will need the latest version of the VESC TOOL as well, V0.88.
This also applies to anyone that wants to update to latest vesc versions and have problems with controls or telemetry, this should fix it for the old Photon receivers.
I have tried your modified 3.35FW VESC firmware with a focbox 4.12HW and vesc tool 0.88 with following results:
modified 3.35 FW loaded into VESC OK
Cannot get FOC motor detection to work at all ( does nothing) but BLDC motor detection works OK
No telemetry at all on photon remote - still shows 255.2 as FW on remote
Any throttle command from remote brings up vesc tool error āSerial Port Error- Ć device attached to the system is not functionalā- only way this can be cleared is by re-booting vesc ( power-down and re-power)
Throttle command on remote spins motor OK on BLDC only ( with current - no reverse on Nunchuk ) even if VESC tool error is present ( as above) but no FOC at all
Installing this modified firmware appears to remove any VESC PPM control via RC remote if ĆART and PPM" is selected from App Settings/General
Canāt tell you exactly but if you use the āsearch on this topicā feature with" short" or ābindā keywords, youāll find hints. It seems to you need to read around post #498 on this topic. Thereās a picture, read around.
