Yeah that’s a bit weird, I would write default app config, reboot and resetup app config, reboot, check
wait did you plug it into the right port?
Lol that would be funny… And to the correct side of the correct port…
I would be careful holding it barehanded unless it’s coated, could easily static shock it or even short across your skin
Did you download the modified firmware?
can i see a picture of your app configuration?
Check the cables one time I had them backwards at the rx side, took me awhile to notice… I was losing my marbles
Looks like u tried that nvm
No i did not and was not aware of this issue. I will update my VESC with it and tell you if it works ! Hope it will The weird thing is that even the gt2b don’t work anymore. Thanks for the mac version of the vesc tool So i just should download vesc tool update the firmware re do all the parameters , motor detection etc
the gt2b shouldn’t work anymore, you set it to uart only.
I m not that stupd bro, when i plug the gt2B i swith to PPM
A quick search in the Photon thread does wonders… Don’t ya think? Yup, update and configure.
True that, i knda stopped watching the thread since i had a bad module for months !
Tsk tsk… Who taught you that nonsense?
My frustration with the remote heh
U could try setting up another vesc… I always just start switching crap out when things don’t go my way
@ElskerShadow Dont upgrade to FW3 ! You will only face more problems.
Also I don’t really see how the photon receiver would cause any of this, since PPM does not work as well it seems like a misconfiguration on your part.
Can you show your real time data from the BLDC tool?
When changing apps, the esc needs to be rebooted for the changes to apply
