so you just changed your phase wires and it fixed your 255 error?
Yes, for me it worked with switching two motor wires and invert the motor spinning direction. It makes no sense at all but now it works Hope you fix it also.
Thnxā¦ got it sortedā¦ dectected and running in bldc hybridā¦
congrats.
you what you swap two wires, then detected in the opposite directions, then inverted motor direction in app?
OR
did you swap two wires, inverted direction THEN detect?
I bumped up the D valueā¦ and switch phase wires arnd in difrent combinations then out of no where it detectedā¦ hahaā¦
Hopefully yoy can sort yoursā¦
I changed the duty value all the to.20 before I gave up. Iāll live with sensorless for now. Really tired to opening it up these past two weeks lol
Cheap slutty sensors love the āDā
I get this error with my torqueboard hubs but I donāt have sensor ?
Thereās no reason to run hall sensor detection if you donāt have sensors
No I just run motor detection
Detection results: Integrator limit: 121.98 BEMF Coupling: 676.60 Unknown hall error: 254
Hello; Have problems detect sensor hall motor maytech please help.
Same here: motors running unsensored, show āunknow hall error 255ā during motor detection. Everything seems to run fine. Is there a problem to fix, or I could just forget about it?
