Because the goal for this Switch was to make it cheap’ish and simple, theres no need to add a regulator onto the board when you can run 2 wires from a local source you have already. Plus this is a stop gap for me as I move onto a smartBMS eventually.
I’ve got a 70 amp fuse, which is the max I would go. Went with three MOSFETs for a bit more reliability on the higher current side by lessening heating on the FETs, etc.
If anyone has used this design , DO NOT hook up the LED power connector to anything, unfortunately the ground for it is separated in such a way that it will short if the board is in an “off” state. I’ll spin a fix to this ASAP and apologize if anyone made these for their personal boards.
Hi @emepror,
did you already fix this issue in the current version on github? If I want to go for higher ampere like 150A, do I simply have to use more mosfets in parallel (like 5)?
There’s a newer revision of my switch now, ill update the top post soon. Less likely to fry things now!
but @The_Dude, koralle is right. You can increase the amount of FET’s to 4-5 for that much current but your going to run into issues with copper thickness and current handling. one way around that is to leave the copper traces exposed and add solder but still going to be a lot of current. One other thing that I would start looking into at more than 3+ FET’s is a simple mosfet driver so its a bit more durable.
The github mentions “provides a convenient on off ability.”
I’ve seen some anti-spark switches on the market that turn on automatically during a kick start, and auto/off. Can you confirm what you mean by convenient on/off?
