I first got on this forum over 2 years ago and built a board back then. It has been working pretty well since then, but I think it is time for an upgrade. I am looking to go to a lion battery pack and possibly add on another motor. I want it to look a lot cleaner and easier to charge
Here are my current specs:
6364 245 kv hobbyking motor
6s 25c 5000 mah zippy lipo
torqueboards vesc
torqueboards motor mount
36t abec kit
caliber trucks
knock off amazon flywheels
tupperware container
imax b6 charger
What do y’all suggest I do, as I am sort of out of the loop in all things esk8
Maybe grab a pair of 6355 motors so you can stick with your caliber trucks. The 6364 wont fit dual unless you get wider hangers and most people stay under 200kv. But that will make the stance wider so keep that in mind.
Then you only need one tb mount/ vesc /pulley and a battery.
