To the guys who ordered Pulley kits:
Would you be okay with a 16t motor Pulley? I have checked with 3 different suppliers (the only ones who make the kind of Pulley we need) and they are all out of stock and have ridiculous MOQ (300-500pcs). One manufacturer is doing a 16t run and is allowing me to add on to their other customers order. So is 16t ok with everyone? I donāt know any other options (unless someone has a 3D model of a 15t 12mm HTD5 8mm bore timing Pulley).
I am good with that 16T.
Iām good with it.
Iām also okay with a 16T pulley though if youād like it.
Donāt have a 3D model of a 15T pulley but could do that if that would work better but 16 is fine in my opinion
Does the 16T pulley only have the keyway a or does it also have set screws?
So a set of 16/36? If Iām doing these calculations right, that means my board will go roughly 3km/h faster. I have no issue with that
Yes, 16/36t
Keyway and 2 set screw holes. Black finish
Too late right? If so will there be extras ordered for ur store
im good with the 16t pulley kit
What are you looking for? I am not getting any extra VESC.
10s 3p batteries
The store is still up, I have not ordered the batteries yet so there is still time. You can just go ahead and buy it.
Whatās the max discharge rate on the batteries? It looks like I might need to support around 60A.
I want to know too, I like my lipos right now and dont know if spending $150 on liions that are 10c is a good idea
I definitely want to know the full specs for the 10s3p for vesc configuration.
Just wanted to update everyone. Pulley kits are coming with 2 belts and a 16t motor pulley. If you want extra belts let me know ASAP (like now). I have closed ordering and everything is getting paid for and madeā¦
@Emerson I will let you know the specs, but donāt have much spare time to look up specs. They are Samsung 25R cells if you want to do the calculation.
Will you continue to carry the belts I donāt know where to but spares
yeah I am getting a boat load extra. If you buy in bulk they are cheaper.
