making a new thread because i assume this could help other BB fanboys like myself. is it possible to take their battery system (with charging, a switch, etc.) and connect it to the vesc/vescs we use? for instance:
I don see how it would connect (only the one cable) but hypothetically would it be possible? if so, could save a lot of people some trouble (some are selling them because of the new battery)
i couldn’t find this topic so sorry if it exists already
The stock BMS is connected to their ESC via that cable (most likely a CAN connection) so if you use it with a different ESC, the battery will give you an error signal (yellow or red light).
You can open the pack, salvage the cells and use a different BMS in that case (but most likely you won’t be able to do that since it’s around 3mm and not many 12s LiFePo4 BMS’s are that small).
