Cant find any direct info on this After alot of searching. It looks possible but can’t figure out the exact process through the bldc tool. My Vesc’s are sealed up, setup and everything is currently using bldc mode. First I’m going to set up Foc mode when i learn how to select the Vesc’s independently . I think the process will be similar in terms of controling the vesc through can bus. It looks like I uncheck multiple esc’s over can bus then use can fwd to select the Vesc’s independently.
First what vesc are you, post a picture u said sealed up you sure its not a ESC most vesc have a micro USB port or old USB port and trying to run foc you have to be carefull because not a lot of vesc can run foc without frying
What motors you using ,battery ,vesc
I’m gonna write instructions for VESC tool… Which is the same as bldc but without wireless
Setup Master a CAN 0 slave as Can 1
Connect to vesc vis usb or tcp bridge(I used wireless TCP bridge over uart)
Enable can FWD 1. Flash the slave with a default config that has “send status over can” enabled. After it’s flashed you cannot connect to the slave because it is now CAN 0 default, which is also what the master is. Disable can FWD and set the master to ID 1. Renable CAN FWD 0 and you are connected to the slave. Set CAN ID back to one and save.
Disable can fwd. Update the firmware on the master, reenable multiple vesc over can and set the master to ID 0.
You’ve now updated firmware over can without having to unbolt the enclosure.
I had the following Problem and i think that the can Connection is the Problem (vesc6):
Two vescs connected by can. Only one is connected to the battery. Update Firmware on the connected one. After uploading it tries to restart the vesc. after restarting it does not have the new Firmware just the old one…
The Problem is that you power the second vesc through the can. Thus the second vesc blocks the first one from restarting for a correct Flash and sticks to the old firmware. I could be wrong… but that were my experiences
I’ve never had issues doing it… Vescs can restart independently just fine with a firmware flash or config change(setting app ie ppm & uart) that requires reboot.
But I’ve done it on the following with canbus plugged in and both escs powered on… Can shouldnt be connected if only one esc is powered
4.12
FOCbox
Stewii ESCape(6.4 vesc with custom BOM)
Thanks Deckoz thats exactly what I was looking for.
Just to understand it better for example doing motor detection.
Can Fwd box unchecked would be on master and can Fwd box checked with a 1 would connect to the slave vesc assuming master is id-0 and slave is id-1 correct
I just recently done this on my board.
The only slightly tricky part is when you flash your FW. ID will revert to 0 (default setting). You’d just want to make sure you don’t get in that state where you have multiple 0s, otherwise out comes the can opener and off comes the enclosure
Starting State (Master ID=0 Slave ID=1)
Set Master ID to 2 (Master ID=2 Slave ID =1)
Can forward to ID1 (Master ID=2 Slave ID =1)
Flash Slave (Master ID=2 Slave ID =0)
Set ID to 1 (Master ID=2 Slave ID =1)
Turn off can forward to connect back to master (Master ID=2 Slave ID =1)
Flash Master (Master ID=0 Slave ID=1)
You are done, motor detect\setting as needed.
Master is 0 and slave is 1 and your USB or Bluetooth is plugged into master
Connect, can fwd disabled on connection tab, your on master, run motor detection
Connect, can fwd 1 enabled on connection tab. Your in slave, run motor detection.
Remember APP and motor config are Read and Saved separately. And you must READ the configs when changing can fwd so you don’t accidentally overwrite the each with the other escs data.
controller ID is set inside of the App configuration General tab.
Send status over can(for slave) is also on that page
Master use multiple esc over can is set on the app configuration -> control type tab (ie ppm or nunchuckcontrol ext)
CanFWD is on the main connection tab next to firmware tab
It’s to tell the tool which canbus ID to connect to when can forward is enabled. So you can change the settings.
