I have an old scooter project gathering dust in my warehouse which never really got used enough by my son. It’s a Razor300 with a 36v nominal (42v fully charged) lifepo4 battery pack. As you can see from the pictures it’s on a rectangular pack, but I’m toying with the idea of breaking it apart, and arranging the cells to fit in a custom esk8 enclosure.
The cells and pack are all in fine condition, and I’m wondering on the pros and cons of doing this. Clearly the major pro is that it’s free (in effect) but what are the cons? Would I be wasting my time doing this, and if not, could I use my spare focboxs with it?
Shoot it down as a terrible idea if so, or tell me to have a go if not… I’m interested in your thoughts
Oh yes, for sure. The only reason I’m even considering it is because it’s something I own already and so the cost is zero in hardware… Just a bit of a project if feasible.
Haha cheers ! The scooter was fun to build, and for a brushed motor (500w 24v effort) overvolted to 36v (42v charged) it flies ! I did a couple of smaller e200 scooters, 36v (24v) 350w SLA batteried as well at the same time. My then 9year old son loved his e200, and would hit 21mph on the straights. The e300 did 24mph with my 95kg frame on it!!
His mates thought he was awesome. I built the e300 for me, with an eye that he’d promote to it, but he’s lost interest now and into other things. So it’s sitting around doing nothing. Seems a shame to just let it rot, and now I’m into esk8 and want to learn to build my own Li ion batteries, ultimately, this seems like a fun half-way-house project to familiarise myself with parts of the process.
I’m gonna do it
Then I’m gonna do a 3rd board with my own DIY Li ion.
dug out the old emails from this order and found the specs. Might have something to work with here after all ?
Rated Discharging Amperage: 10 Amps
Max Continuous Discharging Amperage: 20 Amps (50 Amps with High Rate BMS)
Maximum Discharging Current: 60 Amps
Discharging Cut-off Protection: 25-30 Amps (65-70 Amps with High Rate BMS)
Lifecycle of the whole pack: >85% capacity after 1000 cycles. Lifecycle of single cell: >85% capacity after 1500 cycles, >70% capacity after 3000 cycles. (<1C discharge rate and <1C charge rate), Averagely 2000 Cycles
What do you think ? The project board is only supposed to be short commuter and not a long range cruiser like my other PaleRider build. I can custom make an enclosure to suit, and go from there…
Right, sorry… According to the order email thread I found, it’s the 10Ah version. As it happens the deck I have earmarked for this project is a 16" wheelbase Powell kick tail.
I’d still struggle to make these cells look sleek though. It’s in 6 sections, and I can’t lie them 2x3 format as not enough space, and that’s not even taking escs and bms into account. Would need to double stack and that would be over 60mm at that point. Not the look I’m after. Might do it on a long board though next time where I’ve more space to play with. Shame really.
That’s the absolute perfect deck for this … if it was the 5Ah pack and not the huge 10Ah pack. If you used axial-direct-drive like Carvon or TB and flattened that pack, it’d work though
U probably separate the pouches from each other similarly to as done w lipos. If no one said that yet. Bet u could make it slim. If u do scrap them as u worded it what would that mean. Surely good for something.
