I was using 275C-300C so I think I should be good
And if I do a video Iāll probably get bashed for my cringe 14 year old voice
you may be only 14, but you are a rockstar whoās building his own Anti-spark switches! Kudos man!!
Plenty of folks donāt even try or ham fist it (i killed a couple FETsā¦).
Thanks man! Iāll try and shoot a video today if I have time. Iām almost finished my Broās board so thatās first priority.
According to some pictures, the bottom switch pad is GND, middle is VCC and top is the switch one? Is this correct? @chaka @sl33py @DeathCookies
That doesnāt really help me. What do they stand for?
Great work Lox, for your sake and mine I hope these work out
a 3 position switch - as i understand it:
NO - normally open. So if you push the switch it will turn off. Itās common state is on. C - common? NC - normally closed. So if you flip the switch it will turn on. Normal state is off.
my .02 and possibly close but not quite rightā¦
i think i got it right - watched this same vid a while back. just a few minutes long and hope it helps:
GL!
There is nor VCC or GND on these pads. They are for a STDP switch which has a channel that is normally closed and one that is normally open (just like @sl33py said. The backside should also have a schematic showing this.
Nevermind, I just guessed and it worked first try
Zener Diode started smoking. It looked burnt even before I powered it on. Iāll try the other ones tomorrow. Xt90 loop key for now
That is why you should not just guess and assume it worked. The labels are there for a reasonā¦
What sleepy said,
Strange that you got a smoking diode?
Yea, because even if you reversed the polarity of the Z diode, the current gets limited by the 1Mohm resistor in serial. Very strange
Agreed. I would definitely make sure your other switches have the zenner setup correctly - the perpendicular/horizontal line is at the top iirc. (just see the surrounding layer mask/ink showing the small double line = at the top).
Anything else burnt or swapping the diode fixed?
Well, Iām sorry. It was working fine with my 3s battery and nothing was smoking. As soon as I did the 12s battery, boom.
Iām not 100% sure it was the diode, I unplugged it and guessed where the smoke was coming from. Donāt want to plug it back in. @sl33py @chaka @goldenHusky I can provide pictures if needed. Iām probably just shit at SMD soldering and screwed something up
Polarity was right on the Zener diodes. Diode Line on the silkscreen line
