So just started to wire up my veddar switch and for some reason there is not power to my volt meter any ideas?
You need to supply the other positive pads with voltage. If you look at the back side of the pcb you can see where the trace is routed.
Ok so won’t work with out the fuse ?
Fixed brilliant thanks
