That would be great! how are the V4 TD’s performing so far for you? I don’t see alot of builds with it besides the EXO’s that have yet to be released as far as I know.
I’d like to avoid having to trim the axle as I don’t think I have the tools or skills for that lol
After lots of reading up on the forum and asking around, I’ve decided to switch over to gear drive. I’ve got @Kug3lis TB218 pneumatic Fatboy Mini gear drives to go with my @Hummie deck which I’ve already ordered.
I do plan on running 6.5" Trampa tires on the drives and downsizing to a 12s4p 30Q pack instead to keep the weight more manageable
I also realized that I may not get the torque I need if I go up hills on the Carvons which was one of the reasons why I opted for gear drives
First part update!
Happy to have the first ever part of my build to come in, The Firefly remote! Its abit rough on the edges and on the throttle wheel but shouldn’t be too much trouble to smoothen out! Thanks to @solidgeek and @SeeTheBridges!
My Maytech 6374 170kv Motors and @kug3lis Fatboy Mini 3:1 Gear drives arrived. Parts slowly coming together but have yet to order the N.E.S.E. 2s4p and 30Qs plus the 6.5" Trampa Tires and Tubes. Also waiting for the 3rd Batch of DieBieMS to push through and that should top off my parts list!
Super hyped to see this all coming together! tempted to get a Red Ember The 44 to deck swap with but I might get in way over my budget doing so
Riptide package just arrived. Cant wait to try these out. Now if only I had the trucks and deck
Possibly the start of my esk8 sticker pile
Thanks to @Alphamail for these! almost tempted to try them on the clone trucks and baseplate on my Ownboard but I’ll save it for the actual build
Cover motors well. The magnets inside will suck up any metal shavings. You don’t want that.
I had to do the same. Maybe it’s different with that drive Set up tho. This is what I did tho. I probably wait for someone more experienced to give thier input.
I used a Dremel with a good cutting wheel. Took about a minute to do both Motors.
I left my pulley on and used it as a guide of where I wanted to cut.
But I’m very confident with a dremel. If you’re not, I would take the time to mark it and take the pulley off so there’s no mistakes.
Might even wrap what you don’t wanna cut with a piece of electrical tape? Be a good way to keep track. Just don’t forget to keep that motor covered until after you’ve cleaned up.
You don’t want any of that in your motor.
Okay great, I’ll keep that in mind. I dint have a dremel here at home, is there another way to shave it off? I could find someone local
To do it with a dremel I suppose if I can’t do it my self
Idk…
I bought a Dremel off of Facebook Marketplace for like $30.
I guess you could probably use a hand saw. But I kind of feel like that would be rougher on the inner workings of the motor shaft.
