Hope you can help me find the solution.
here’s my setup: mountain board with E-Toxx dual Direct drive, Dual VESC 4.12, 12S 100Amp Lithium battery, 75Kg rider Config and fault code below. Under hard acceleration power cuts then resumes as I reset the throttle. Using 10s with higher Max motor amps works fine. I wanted to keep the high motor amps setting for maximum torque.
The following faults were registered since start:
Fault : FAULT_CODE_DRV8302 Current : 56.0 Current filtered : 45.1 Voltage : 48.04 Duty : 0.48 RPM : 24167.4 Tacho : 74572 Cycles running : 51041 TIM duty : 3880 TIM val samp : 1936 TIM current samp : 6001 TIM top : 8130 Comm step : 3 Temperature : 20.77
Fault : FAULT_CODE_DRV8302 Current : 57.8 Current filtered : 49.6 Voltage : 48.34 Duty : 0.28 RPM : 12681.9 Tacho : 199450 Cycles running : 25293 TIM duty : 3513 TIM val samp : 1754 TIM current samp : 8089 TIM top : 12670 Comm step : 3 Temperature : 23.33
Fault : FAULT_CODE_DRV8302 Current : 55.0 Current filtered : 47.3 Voltage : 48.08 Duty : 0.35 RPM : 15783.9 Tacho : 203444 Cycles running : 30775 TIM duty : 3691 TIM val samp : 1844 TIM current samp : 7079 TIM top : 10470 Comm step : 3 Temperature : 25.27
