I have a razor e300 scooter running esk8 vesc 4.12. Running with a keda 190kv outrunner, 10s6p battery. (Gear ratio has been increased for acceleration)
I’ve been running on foc for first dozen rides and its fast! Anyhow, I’ve recently tried out bldc.
For some reason bldc is really down on power compared to foc.
All settings are the same, ie
motor max is 80a
Battery max is 45a
Power max is 2000w
There’s no restrictions according to the graph but the motor is not pulling enough amps.
Idea: Leave it in FOC! I just recently changed my board back to BLDC to see if it resolved an issue I was having. I ended up going back to FOC. It’s just more powerful. You loose a little top end speed but its worht the loss, in my opinion.
I changed it to bldc because I was having problems with foc.
When I’m free wheeling sometimes I struggle to re-engage throttle. Occasionally I have to roll to a stop and gently feather throttle until it comes back. (Nothing to do with overheating, etc and no faults logged).
There must be a reason why the motor is not pulling many amps in bldc.
I’ve restricted my top speed because its silly fast so not bothered about top end anyway. It’s the acceleration that’s fun.
You are using the vesc from hobby king? Anny issues besides the magical ones here?
I actually had the same issue with regular 4.12 vesc that was hand soldered. I only used bldc, foc detection did not work at all, not even for R and L parameters.
But in bldc i never saw motor current rise to the top limit that was set.
