Hello!
So I went out to try my board outside for the first time today and it has already tried to kill me at least three times.
I have the Nyko Kama connected to the vesc. Soldered -> JST. It works flawlessly inside my home and did periodically outside as well. However it cuts out insanely often and it’s sometimes even hard to get the signal back, this has NEVER happened in my apartment (currently 3 meters from board and it’s constantly connected and everything works).
I have noticed my VESC blinking red 3 times on boot and once when disconnected. I cannot get any fault codes out of BLDC by typing faults. “No faults registered since startup”.
I redid the soldering on the reciever and it seemed to work for a bit, but then the board tried to kill me and it was back to being as horrible as before.
Suggestions? Do I live in signal mekka or what the hell is going on?
Edit: Also tried to wiggle the shit out of all cables to see if theres a loose connection on either nyko or power source, cannot get the remote to disconnect and cannot get the VESC to reboot by doing so…
NEVERMIND THIS (woks fine when I disconnected the Nyko Kama): Noticed it just makes a click noise when trying to control through BLDC with keyboard which seems like DRV fail but works fine with remote and so does motor detection.
