Hey!
This is my first build and I want to start with a mountainboard with dual setup!
I read a lot of topic but some questions still exist so better ask!
Hey CS !
Good start , no problem for your wiring, and yes the last connector you need is the // one (before your swith and then vescs and motors). But that is a lot of wiring and XT connectors !.. secures them for emtbing !
Tcheck Colson link, maybe Idea could also make the mount for your actual trucks (but I will go with a spring upgrade too)
No you don’t need it (but you could if you want to charge them easyer way…not sure about that too, deepending of your chagrer. I got a dual raktor working good actualy).
You got a solid pack I make a 12s 8ah with 2x 6s8Ah15c Graphene too (but low C rating in this conf.) and it work all good.
I used lipo also on my emtb and other build, no worries for you and your pretty hight discharge capacity (if your carrefull when wiring them correctly).
An other good way to be sure :
https://img4.hostingpics.net/pics/788428IMG20171028192816.jpg
Not from your scheme but from your VESCs picture.
Tell your reseller that he’s selling wrong CAN-bus connectors.
Only the 2 middle wires need to be connected, not the black and red one.
That can lead to fry your VESC.
