The title says it all, my USB broke off my VESC took some of the PCB with it lucky enough it was just for the pads that held it on.
I was now thinking about just putting the USB cable on it, removing the connector and yeah just get that put on there.
Would that work? I know I’m going to have a cable hanging now but I can totally live with that.
Or should I try to get the original connector on there again? I still have it and I can still use it with BLDC tool since I just hold it on the connector (Works awesome, updated firmware this way)
Oh, and does anyone know any that repairs them in EU? I have no hot air station so I cant fix SMD components.
Not entirely clear from your story, but are the solder pads of the PCB actually in tact or not? Soldering the usb wires onto the PCB is going to be a very difficult job. The pads are very close to each other and you may overheat them by trying to solder those tiny wires onto it, which will lift them off of the PCB and permanently damaging part of the PCB trace.
If the pads are intact, it’s easiest/best to contact an SMD soldering company to ask them for a favour. Shouldn’t take them more than a minute or 5.
