Hi, I was planning on using a Turnigy VESC with a KEDA 190KV motor. The VESC says 50A continuous and around 250A burst but the KEDA says it’s 80A. Is this a problem? If this won’t work, is there an alternative motor which needs less current? I’m planning on running at 8s
be fine. you program the vesc’s amp limits
it won’t be a problem. problem is u don’t know how to use vesc right now. go read some thread pls
Ok, some more research needed
Thanks
hello, im looking buy the same motor and vesc. what you say about that, how are they behavior
The Keda is a good motor… plenty of oomff with a single VESC setup. I am running 12s though!
