It’s not my first vesc so I don’t know what I’m doing wrong but while accelerating the vesc cutsoff.
Gear:
6s 5000mah lipo 25c, 245kv motor.
Vesc settings:
BLDC
Motor max: 85a
Motor min: -60a
Battery max: 30a
Maximum input voltage: 57v
Minimum input voltage: 8v
Cutoff voltage is very low just for the try.
I tried to change every possible settings I could think of but it acts the same, it even cutsoff while braking hard.
I looked for errors in the terminal but there are non.
@scepterr Seems hot when I touch the hit sink.
Another thing I’ve noticed is soon as I squeeze the throttle all the way the vesc stops and there’s a weird sound from the motor.
If I don’t push it all the way I can go up the hill.
Tried to recalibrate the rc, didn’t work. Tried to replace the motor, didn’t work.
It seems something with the remote or with the current peak.
It does not matter what is the battery max it keeps on happening.
If you don’t see the VESc throwing a fault in the logs then it could be your battery. If your trying to pull more amps than the battery can supply (or BMS is configured to allow) than the BMS could be temporarily cutting out (by design). What battery/bms do you have (what’s the max discharge ?)
@Esk8HubsUS@jmasta I don’t use bms and this battery is working fine on a different board with the same setup but the vesc.
I put the start and end cutoff to 10v and 8v just to make sure it’s not any battery sag issue.
@i2oadsweepei2 nope, totally different. The motor is not braking and the noise is different.
So when you set the 40 amp battery max the vesc can only take 50a continuous, but then when you set the motor max it’s based on the max amps of the motor not the max based on home many amps continuous the vesc can take? Right? (Sorry trying to learn)
