Hey everyone
A buddy of mine is using 2x esk8 VESC 4.12 in his mountainboard and he’s got a the weird problem that his setup only draws ~1400W total.
Here is his setup:
2x esk8.de 170kv 3kW Motors
2x esk8.de 4.12 VESC
Zippy 10S 8000mAh Lipo
15:80 Belt Transmission
We tried in FOC and BLDC and didn’t touch anything in VESC Tool besides Motor Detection and different Motor/Battery max combinations (of which all should have used much more than 1400W in dual). The Turnigy Wattmeter only shows 1400W even with full throttle (which is also fine) and i don’t know what to test further. His whole driving experience isn’t that great so there’s definitely no fault in the wattmeter.
I’d consider myself as fairly good with VESCs so i don’t know where to begin troubleshooting. Any input would be appreciated!
It’s inline and i also thought about it. It’s a 100A 60V turnigy wattmeter so that at least shouldn’t be part of it’s function. You also can’t find anything online about that. I will urge im to try without meter but i don’t know if it’s easily removable since he bought it used.
@myreala the wattmeter shows peak values and they were produced while driving. I’ve tried it myself, could pull full throttle and barely move.
