Torque board 6374mm 190KV, 80 amps max
hummm that weird, Are you sure it is a DRV faults and not something else?
also, personally I would put the motor max at 70Amp.
Are you running sensored? Any malfunction on the sensors will throw a DRV fault
A few weeks ago I thought I had also killed my VESC 6, turns out that if you do the sensor detection and change the order of the phase wires you have do the sensor detection again
Itâs kind obvious but I hadnât realized at the time
I thought that high current limits are more likely to cause issues!!!?
Yeah, i m using sensors! Let me take a closer look one more time.
First thing to do is run unsensored them to confirm
Not really, It is problematic if you go too much over the limits.
But I think @Pedrodemio might be onto something here.
Just tried! no luck. I think drv is gone! Blinking red, fault code = drv
Is the light blinking all the time or just when your try to run the motor?
Only when i try to run motor
hummm⌠yeah sound like a DRV or a blown Mosfet.
Thanks! Well, If this keeps up, iâm gonna end up giving up. Itâs been too much money spent so far
Paging @trampa
I think the warranty is more than 3 months
And I think Vedder would definitely would like to take a look to see what happened for a fail with no apparent reason, even more since you were running really conservative values
Does the error say anything more? Type faults at the terminal and post a screenshot here
I also just noticed that itâs not completely dead, the motor just worked a couple of times!
Ground under volt on the DRV, donât know what could cause that, can you post a picture of the internal of your board?
I just put everything back together probably later on! Thanks for all
Maybe gate drive undervoltage fault?
If so, a few things can cause this, either the gate drive bypass caps have become a short, something (debris) is shorting the gate drive rail, or the charge pump on the DRV8301 is busted.
Hi @SkateYS , you need to get back to us via mail. david.garlinge at trampaboards dot com Would be the first ever VESC SIX with a DRV issue. What else did you attach to the VESC? Bluetooth module? Please also check your motor and connections.
Check your screws on the motor mounts. If they too long they could have shorted the phase wires, what could fry the drv. If thatâs the issue it will happen again and again till you fixed the phase wire isolation.
