I tried the suggested settings and the brakes were still weak. With this setting they seem better but cut off when I get to a certain speed. Would that be something to do with “Max ERPM at full brake”?
Am I right in deducing that the faster you’re going the more vigorous the braking power?
I dont think there is a problem within the bat min max and motor min max. Try to redo your BLDC motor detection. You might also be off with wrong firmware - hardware issue.
yes the current is the constant current applied, min ERPM is the threshold it need to obtain the low duty is the duty cycle at the end of the detection sequence
motor max: 80
motor min: -80
batt max: 40
batt min: -20
try this? batt min -20 is pretty much the max you can go with your setup without damaging your cells. (This is debatable, tbh i dont know your cell capacity, this is assuming they are 10 000mah)
If your brakes are still full of weak sauce, i would revise your setup, double check all your connections and such
I used to run my motor max at 60a.
Then I bumped it up to 80a and got a noticeable increase in low speed torque and my motors still run relatively cool.
That’s why I suggested 80a for motor max.
With a single drive using a 5065 236kv motor,
Your not gonna have a lot of torque and therefore not a lot a braking power.
A more suitable choice for a single drive would be a 6374 motor.
With all due respect, with my last ESC, a 120A boat ESC I had great torque, could start from a stand-still on a slight hill, no problem, and the brakes were quite good . . . when they worked!
Problem was, I could never tell when they’d actually work so that’s why I wanted to get a VESC, also the speed gain was a bit harsh, sometimes if it took me by surprise I could have easily tumbled off the back of the board if I wasn’t as quick to react.
I’m sure I just need to play around with some more settings, to get it as good as my old ESC but with less punch and more reliable brakes.
To be fair, I’ve only tried these settings inside, within a reasonable run, front of my house to the back, so I think outside they’d probably behave a bit differently…
