Hi there, I’m very close to completing my board, the my VESC isn’t cooperating. I’ll start by giving some basic information.
Enertion VESC (ordered about a month ago, received 2 weeks ago) Motor:
Batery: http://www.hobbyking.com/hobbyking/store/__8851__ZIPPY_Flightmax_3000mAh_3S1P_20C.html (I know these batteries won’t last long, but my priority is for them to take the least amount of space possible since I have a pretty flexy deck.
Now, for the actual question.
Whenever I try to do my motor detection it doesn’t work (The motor does actually nudge a bit when I power it, it also nudges during motor detection) and when I go to the realtime data tab and I try to use my remote I get the infamous ‘drv8302’ fault.
This is the way i have my VESC connected to my motor, I know this is not at all an optimal connection, but I have no proper connectors yet (i’ll just solder everything in place when I know it works) nor do I have access to any connectors atm, since I pretty much drained my bank account by buying all the parts (I guess some of you know the feeling? :D)
Could this be causing the issues I’m having, or is the VESC faulty for sure?
Also, has anyone ever used the motor I’m using, I haven’t found the perfect settings yet as the settings could probably be causing the issues aswell I suppose.
I’d really like to get some help since I’m looking forward to riding this board A LOT.
Thanks guys
