Hi i have big problem, my vesc dont detecting my motor. My setup is:
Sk3 6364 190KV 2x Turnigy lipo batteries 6s and 4s multistar 10c Vesc 4.12 turnigy Sk8-ESC FW:3.38
My vesc was have old FW and before first connect i was update my FW to 3.38 After this i connected the battery (serial connect to 10s) and my motor. Vesc tool connect ok. i chose motor setup wizard i chose BLDC In motor max i set 50A in min -40A Battery i set to max 30A and -10A and i chose sensorless type
And i try to detect my motor in wizard. Unfortunetly red lights on vesc blink a few time and program say detect fault
after this i enter to terminal and write “faults”, this is my output:
The following faults were registered since start:
Fault : FAULT_CODE_DRV Current : 0.2 Current filtered : 0.2 Voltage : 41.82 Duty : 0.008 RPM : 0.2 Tacho : 5 Cycles running : 1 TIM duty : 423 TIM val samp : 211 TIM current samp : 25604 TIM top : 50785 Comm step : 1 Temperature : 30.25
Fault : FAULT_CODE_DRV Current : -0.6 Current filtered : -0.2 Voltage : 41.85 Duty : 0.009 RPM : 6.4 Tacho : 8 Cycles running : 2 TIM duty : 446 TIM val samp : 223 TIM current samp : 25470 TIM top : 50495 Comm step : 4 Temperature : 30.33
Fault : FAULT_CODE_DRV Current : 0.4 Current filtered : 0.2 Voltage : 41.83 Duty : 0.008 RPM : 3.6 Tacho : 11 Cycles running : 1 TIM duty : 415 TIM val samp : 207 TIM current samp : 25646 TIM top : 50878 Comm step : 1 Temperature : 30.39
Please help. mosfets on vesc looking good
