Any one can help where to check for drv error also it is only showing blue and green light what does that mean , i know my drv is blown but where to check in bldc that “drv error”…
Try in bldc tool / terminal and type in faults
My vesc isnt connecting with computer
Its showing no firmware read response
Try another USB cable Some USB cables only supply power, and don’t have the extra data wires.
Mine is from ardunio nano, it is a data cable for sure
It is data cable
Showing no firmware read response
Also it might be worth installing some usb drivers for the STM32, just in case.
I was actually thinking that , will try now
installed drivers still shows no firmware read response
installed drivers still same issue
why are the blue light and green leds on vesc for?
It worked , i typed faults it shows fault code none
Blue is power, dim green means it’s running correctly. Bright green means it’s outputting to the motor. Red means errors, three red flashes means DRV error specifically.
no such thing , its showing no faults since startup
there is no red led is flashing, there is dim green light, but there is hole in drv for sure
