Just noticed that there was a blue light on in my enclosure when my battery was plugged in charging. I have to assume it was the VESCs, as there is nothing else with a blue light in the enclosure… is that normal behavior?
The battery switch itself was off.
My power pack is from TB. Its basically a space cell 4. 12s4p with the integrated anti spark switch, charging port, LED % indicator and 2 USB ports in the packaged battery.
@cwazy1 My 6S4P from them does the same thing. I found that out by playing with the remote while the board was charging and the motor started spinning.
I would assume that means that the switch inside the battery or whatever has failed and is now always on. I’d recommend physically disconnecting your battery from the rest of the board or else it’s gonna over time drain the bat really low, until the BMS cuts it.
@JdogAwesome I can still turn it off using the switch, but when plugged in to charge it powers everything on. Why would that cause the battery to drain really low when it’s charging?
Oh I didn’t realize that’s what was happening, no if it’s charging and it turns it on then it’s not going to discharge, it’s just going to be on so yeah. Though that sounds weird and I doubt it’s normal you might want to check out your wiring or maybe get a different BMS.
It sounds like thats just the way that the TB power packs function, but the real question is… does it do any harm to components downstream of the battery, ie your VESCs by having them on all the time while charging.
