Hello Guys, so, my board is almost done, but there are some things that I think would make it better, like the capacity of using it with reverse… but the tutorials I saw telled me to use “Current No Reverse with brakes” and there is no option like “Current with Reverse” and I don’t know how to configure DutyCicle, I really want some help, tomorrow I post my configs. When I use dutycycles the motor get crazy and when I brake and turn the trigger back it start going full throttle, help mee
Another issue is that red light blinking, because I really don’t like to wait that 3-4s to start using my board, would there be a way to remove that?
Current control is the reason the vesc is so nice, current is constant and the duty cycle is dependent.
In duty cycle mode, the duty cycle is constant and the current is dependent… meaning the current can be potentionally infinit, busting the hardware. (Main reason why you are hitting a cutoff limit)
Duty cycle mode is mosly used in robotics, for a skateboard, current control is the way to go
Oh, that is a good explanation, you convinced me, another thing that I want to ask in the same threat, sometimes when my motor goes one direction the Belt go to the outside of the pulley, when I go to the other direction it goes to the inside of the pulley, what can it be?
Tbh, the only reason i see for going in reverse is for deerping around.
But to answer your question, most likely your wheel pulley is not perfectly true with the motor pulley. To a certain degree this could be hard to obtain.
I always ask myself, is it good enough for the girls i go out with?
