My name is Dylan and I am building an electric mountain board. I have a dual 6374 190kv motors with 2 vesc connected to 3. 4s 6000mAh 14.8v 50c lipos so, 12s total in parallel. The reason for the post is i wanted some help because my wheels spin but, i want to get the most out of the board. I have a 12t pinion gear and a 48t sprocket. So any advice that would be great thanks.
Dylan
The size of you wheels (200mm , 250mm something else?), the type of transmission (chain, belts, gears), your terrain (flat, hilly) etc would help in order to provide better suggestions.
than take this settings and set the half of the batt value in each vesc. the vescs are in parallel so they the totall batt amps add up, keep that in mind.
