Just wondering if these wires
http://www.hobbyking.com/hobbyking/store/_102160__JST_SH_6Pin_Male_Plug_with_200mm_Wire_Pigtail_5pcs.html
would plug into the vesc sensor port, as then I could use these to wire from 5 pin to 6 pins.
Thanks
Thanks
you want JST-PH 2.0mm 6pin. The ones you linked are 1mm pin spacing. Will not fit the VESC. You need the 6 pin JST-PH 2.0mm:
