I have a problem with my vesc-x. I just got the drv8302 chip replaced after a failure but now the vesc wont connect to the bldc tool and it does not take power. The lights on the vesc does not turn on either.
Sounds like either the DRV wasn’t replaced properly, or something else is fried, maybe the 3.3v regulator. Double-triple-check all your work, under a magnifying glass and strong light, etc.
Look for burn marks or blistering on or around any components.
Look for solder bridges between pins, and make sure the DRV chip is perfectly aligned with the pads.
If you have a multimeter, check the voltages on the 3.3V LDO. If you have no 5V input to the LDO, the DRV was soldered poorly, and if there is, there may be a short somewhere else that is pulling the 3.3V down and hence no blue LED. Try to see if anything is heating up, even barely.
