So this could actually be used as a Trampa Sous Vide?
Maybe we should publish a book called cooking in FOC.
as long as you donāt trademark ācookingā, thatās fine
Maytech was teasing those, I wonder if they working together.
Definitely not.
TrampTech
haha, sorry for the teaser pic. and sorry if you had to answer unwanted dms @trampa
Without saying too much;
Yes its at 75 volt/300A.
No its not a multi esc. its one. If youād consider the cable girth for 300A for a second you might add up why theres so many wires.
The boiling motor part is true tho. (stress heat test)
Iām sure Ben will share some info about this when right time comes.
On the roof? Novel but wonāt make it handle better! Needless to say I want one
An EV ran With 2 VESC ??? Is this forul will become electric vehicle builders in the future ? Actualy this sound amazing.
Iām building a Volvo P1800 atm, let me know if this thing is available, I could be your rat lab if these VESCs are available.
More space here!
Our sparky has one of those. Gray, no windows in the back. More space for batteriesā¦
I think the Mini is a great car for e-conversions. Light, small and it comes with a gearbox that can be easily coupled with a 30KW BLDC motor.
As soon as the 300A version is stable, we will try to organize a pre-order sale for a small batch.
Frank
I can already tell there are dedicated mosfet gate drivers per phase and not the ones coming off the DRV chip. This is not a secret because of power requirements to drive loads as high as an EV.
What anti spark switch are you using with that. Seem like its the only thing that cant be made reliable lol
If anyone needs something this powerful, look up 300A vesc. Itās made by user TechAUmNu in the fightingrobots forums and it costs just a bit more than a regular vesc 6. Heās already had the first batch of preorders filled but Iām sure heāll be making more
DRV has voltage limit of 60V, itās 75V version so itās bit no brainer that it will have to use separate gate drivers, plus it also has 12V rail which indicates gate drivers
A relayā¦
Iāve been messaging him about his product. Itās the A200S 16s 200A I believe. I think theyāre ā¬400, maybe a bit more, but right around there. They look very high quality. I asked about dual enclosures and using them in Esk8, he said heās doing to start making dual enclosures, so that would be perfect for running something like 80100 motors at 16s, I think you can actually run up to 18s with a few modsā¦ Anyways, a build using these and the motors to match would be unbeatable!
So instead of simply making low cost vescās that donāt fry or blow up from normal use, you decided to make something I would never need? How about just a nice cheap vesc that is robust? or how about a simple 100amp version that is bombproof?
