Hello i want to buy a vesc preferably made by a known company not maytec for around $80-99 shipped A vedder anti-spark switch $35-40 A 12mm 15t motor pull with 3mm key way Some 12mm belts that will fit a 15t and 40t gear setup on tourque boards motor mounts.
Hi,
I offer vedder anti spark switches for 29€ including shrink tube and stuff. You can check out my thread here:
Your options for a VESC at that price point are limited to DIY by my knowledge. Unless you want to build it yourself…but then you’d need equipment which will cost you a lot, and you may break some things along the way (that’s what I did at least).
