hello looking to buy any sort of esc for a dual set up or just a simple vesc
I already have one vesc
If you buy “simpel” you will buy twice
ps never mix esc oder vesc if possible
okay its my first build if I can get a dual esc I wouldn’t use the vesc but if I get another vesc it says I can use the canbus connector to run dual
It is possible to work with canbus. But differed vesc dont always like each other. its a risk you could possible run into.
btw there are dual motor vesc aio options
could you link one in or are there any like locally such as in the uk
Search the forum (there may be a couple) Or keep your eye on ebay for one
