Wanted switch like vedder
So I’m after a switch or a kit like vedder I seen a few people selling similar kits like sl33py but not sure if he has any left. So either a complete item or a kit depending on price. Will only be running 6s. Forgot to add needs shipping to uk or uk supplied one.
Have you asked if @sl33py has any?
I have some vedder switches.
I think i have 2 or 3 left. They are a kit, so it’s DIY and SMB soldering is needed. You can also check them out on esk8.de and Miami electric skate’s site - fully made.
I don’t want anyone to get a switch they can’t assemble. A fun project for sure, but if you haven’t worked with hot-air rework or reflow oven to solder these it can be a bit daunting.
pm me if you want a kit - and looks like barajabali has some as well. Good to have options!
Ollin board co has them as well
How much are they
I got mine from esk8.de (@elkick) and it´s definitely worth the price. Having a real switch is much more intuitive than using a loop key and the changeable car fuse makes sure that you won´t accidentally burn your VESC.
DIYes also has them
Just FYI, DIY and Miami are similar switches, but are not the vedder/fechter switch. In using DIY one and has worked great so far but there is no fuse/holder
Yeah it’s definitely daunting. I bought parts for three and can’t get a single one working. Once I have time I will diagnose the issue.
What does it mean didn´t get a single one working?
I know from own experience that the switch only works with some consumer (eg motor, led) connected to the out ports. When i got my AS from esk8.de i tested it on the bench with just a 12V power supply at the in ports and my voltmeter connected to the out ports and it didn´t work, then after putting it in my esk8 setup everything was fine.
I must have screwed up somewhere.
Use something to bypass the xt90s and see if you still have issues. Maybe some spare 10-14awg wire.
@Blacksheep
I have two switches. vedder and the standard high voltage switch.
both of which are very reliable. vedder more so than the high voltage switch. but the high voltage comes with a warrantee in case you get a dud.
48 for high voltage 45 vedder
https://electric-skateboard.market/product/high-voltage-onoff-switch/
check it out.
