looking for a waterproof sealer 6374 190kv motor in Europe.
eskating.eu has exactly this. 190KV 6374 sealed and waterproof. Am looking at the 6355 version for a build I’m planning.
out stock atm but back in stock early November thanks sent them an email. they also don’t stock the 3mm key for the keyway
What about heat? Where does it go, dont know if these motors heat more than open ones if dont im buying one
I have this exact motor. 100% recommend. They have keyway as well I think. Or use threadlok it works fine
are you looking for water-resistant or water-proof water resistant means you can ride through puddles water proof means you can ride on the bottom of a lake
brushless motors are naturally water resistant. just make sure to wipe off the outer case (thing that spins) once your done riding through water
edit: spaced out, it’s called the can
yes. go on, place the order… you know you wanna
oooh that rhymed grec in the place tonight yes aiii
What is the difference between:
https://street-wing.com/product/6355-190-motorbike
and
The eskating.eu one seems to be rated at a much higher wattage for example…why? @DavidBanner
It’s a different motor.
If you check the specs on eskating.eu: “PLEASE NOTE: This 6354 Motors are longer than normal so just use 9mm width belts and pulleys to let them fit perfectly (dual drive systems)”
Maybe they are using longer stators, hence the need for a larger can? Possibly it’s actually a 6365 sized motor?
