Wattage is volts times amp would be the obvious calculation.
I’m aware that motor amp is higher than battery amp due to the stator in the can spinning which is why battery amp is set lower than motor amp in the VESC.
Is the actual wattage for torque calculated off battery voltage and battery amp or off battery voltage and motor amp?
I also assume that amp rating limit for motors set by factories is based off total motor amp instead of just amps being drawn into the motor from the battery?
Well you stated “Battery current * pack voltage = electrical wattage” and then stated “motor current * (pack voltage * duty cycle %) = electrical wattage”, so when talking about wattage for motor torque, which one of the two is it?
I understand what duty cycle is, but at 100% or near there times the higher motor amp would give a different answer.
Also Chewie says battery volts times motor amps (unless it was just a simple mistake and he meant battery amps).
See why I have to ask in an attempt to understand where the wattage for motor torque is as the calculation would give different answers.
only when the duty cycle is %100 can you use either battery or motor amps * pack volts because the motor amps and battery amps will be the same at 100% duty. also at 100% duty cycle, the effective voltage of the controller is the same as the battery pack voltage. (but the max duty cycle of a vesc is 95%…)
when the duty cycle is anything less than 100%, than the correct answer is battery amps * battery volts = electrical watts (not motor amps * pack volts for electrical watts unless 100% duty)
motor torque is directly proportional to motor current.
KT * motor current = torque in newton meters
KT = 60 / (2 * pi * kv) = torque in newton meters per motor amp
Like I said, any wattage rating listed is marketing propaganda. They’re going to take the largest number they can come up with, which in this case will be motor amps, times volts, and not worry about duty cycle in the least.
