@karma I run FOCBOX on 13s with 120A motor current. You see, the FETS are rated at 75v and upto 250A with proper cooling, if I’m not mistaken (need to check the data sheet again). The Focbox copper pours are rated for 50A @ 60V.
ESC are basically a buck converter. Varying the duty cycle. You can find lots of my posts on duty cycle. But the answer is simple.
Motor Max 120
Battery Max 50
Voltage 54.6
54.6V * 50A = 2730Watts
2730Watts / 120A = 22.75v
22.75V / 54.6V = 41% duty cycle.
So above 41% duty cycle the motor amperage will drop the meet the maximum battery amperage/wattage.
2730W / (54.6V * 42% Duty) = 119A
2730W / (54.6V * 43% Duty) = 116A
And below 41% the motor amperage can be upto 120A. Meaning more power to the ground during acceleration giving you your maximum output potential throughout the entire band. For example. Duty cycle comparison of actual output
Motor Max 60A
(54.6V * 10% Duty) * 60A = 327Watts
(54.6V * 20% Duty) * 60A = 655Watts
(54.6V * 30% Duty) * 60A = 982Watts
Motor Max 120A
(54.6V * 10% Duty) * 120A = 655Watts
(54.6V * 20% Duty) * 120A = 1310Watts
(54.6V * 30% Duty) * 120A = 1965Watts
As you can see, all examples are lower than the Battery Max 50A @ 54.6v (2730 watts) and also within the limits of the pours, 50A @ 60v (3000Watts), and the amperage is well under 75% of the rating on the FETs.
So with the right cooling for the ESC, a big battery and the capability of the ESC, why leave all that power on the table if you are within the limitations of the hardware…
Just saying
Edit: my point to this in the original topic of the thread, was sensored FOC helps the controllers accurately calculate motor angle, so no power is wasted from bad timing. The mixture of a clean phase timing, with lots of power, and traction control enabled so that the controllers can measure slip and not torque out makes the whole combo turn into
sauce.
