Hi.
I got foxbox 2 months ago. Should I update it? Or it already has newesy versions?
Btw anyone knows what options may reduce motor temperature? Focboxes are cool, maybe 40°C but motors are very hot, for sure hoter than 65 degrees.
I read sth about changing duty cycle but idk if there is sth else that could help.
My setup
Dual 10s 192kv brushless sensorless motors. Mountainboard 8" wheels, 1:4.55 reduction.
Thanks for any help!
The FOC box is a 410,411,412 hw. You shouldn’t NEED to update it but you are welcome to. I like to use @Ackmaniac firmware which would require you to update the firmware with his.
Are you running BLDC or FOC? Changing may impact your temp. We would also need to know your motor/battery amps to help solve this.
Oh xd how do I know what hw it has? I mean 4.10 or 4.11 or 4.12? I do not get it
My motors : turingy 6374
Battery -> 4x li po 8ah 5s 30C which gives me 16ah 10s 30C, they are literally cool so they are ok I do not have a bms, i control cell voltage with my battery.
I am running foc. I do not want to use akmaniac filmware because of warranty xd. I know that I can but I would prefere not to do it.
i dont think you will find any way to decrease the motor temp other than decreasing your gear ratio or reducing the current to the motors with the vesc settings. higher voltage wont help
I read 2 posts where people said that they updated filmware and changed some frequency and it worked then. This is why I wonder if there is sth else. And I do not get this 4.10 4.11 4.12 fw xd. I literally dont know why are there three versions and if I can update it. Btw after updating filmware do I need to configure motor settings, detection and so on once again?
