I have a single 6374 on my first build. This second build is for my son who only weighs 130 lbs. Do I need a bigger motor than 5065 if only going with a single motor?
Acceleration will be lower ofc, make sure to set the temp and Ampere limits appropriately and then it’s fine. It’s a lackluster experience once you tried a dual 63XX setup but for a light weight rider crusing and comuting pretty enjoyable.
Your main concern should be braking. Those brakes will be really poop, borderline dangerous depending on your riding environment?
@Russell23 ran a single 200kv racerstar 5065 for a long time. As far as I know he had no problems with it. He’s light as a feather too.
Yes but Russell rides at 30mph up sheer walls while texting. He’s not a good example
