i managed to break those 2 electronics and whenever i plug my esc into them with a 3 pin connector it doesnt work, however if i just use the esc and batttery without them it works fine, is it some sort of bms??
edit: after googing zad-b5 i came up with what looks to be the first green electronic, apparently its some bluetooth amplifier audio?? sounds useless but i still dont know what the other thing is
idk what they was but i yeeted them mfs out and kept battery and esc only also disconnected motor sensor for more power
the amount of information and clear pictures is staggering
Those look like phantom kohmingulators. What they do is prevent you from falling off the skate. Generally, you can ride without them, but you need to wear a helmet.
dafuq is that
Search ebay for the phantom kohmingulators, they usually aren’t too expensive if you can find one used. Just don’t get the flipsky branded ones, they will probably blow up…
brOOOoooo Cheyna is spying on you with those EleCtonics :0000
Broooo BroooOoo broo
i need to get my hands on some of those
Ive been extremely happy with my phantom khomingulators. They gave me about 10 more miles of range!
I’d agree theyre definitely a good investment. They’ve saved me from a couple of falls since i bought mine back in march of last year
Aw man, haven’t installed mine yet! Now i got a reason to do so.
i literally cannot find a SINGLE item called phantom kohmingulators
What search engine are you using?
i feel like im getting trolled
Nah, you can trust anyone with the esk8 bro badge, they wouldn’t troll.
Agreed, I would trust my life with those esk8bros badges
