What to do with the freshly delivered Space Cell?
Hello everyone!
Short question.
I just got my battery for the raptor but have no board for the upcoming weeks.
Do you think its a good idea to just let it sit around (32% currently) or should I charge it up?
Thanks
40% is about the best state to leave lithium based batteries at for storage. 32% is good too. Keep it in a cool/dry place and it should be ready to go when you have your raptor!
Thanks! Ill charge it up for a bit and then its going to see the inside of a cold dark place in my apartment :wink:
40% of 42v ??
For 18650’s I think the recommendation is 3.7 volts per cell for longterm storage
42v is full charge so yes. Unless I’m misunderstanding your question.
@csn All the new 18650 cells I’ve receive ship at 3.6-3.65V. That would, presumably, be the ideal storage voltage from the factory. That’s for Samsung 25R.
Edited:
You are not accounting for voltage settling after the charger shuts off. Charge to 3.7 and the voltage settles to 3.65v after a bit of time.
Haha guys! Im a total noob when it comes to these electronics.
My space cell (enertion) is currently 32% charged and my question was, whether to charge it or not until the raptor arrives in a few weeks
And id love someone to explain these 3.65 or 3.7V per something :smile:
Your charging-display monitors the voltage over your batteries.
I don’t know the settings of the voltage meter that enertion uses, but normally 4.1V per Cell means full and 3.3V per cell means emtpy.
4.1V(full) - 3.3V(empty) = 0.8 Volts.
0.8V / 100 * 32(your percentage) = 0.256 V left.
3.3V + 0.256V = 3.556
Your cells seem to be around 3.556V wich is slighty below optimum storage voltage.
If you want, you can charge your battery to 40%, this should also balance out all the cells.
If I’m wrong, I’d be glad to be informed :slight_smile:
Alright! Thanks, seems legit!
Thanks @chaka. Does voltage sag occur without an electrical load? I’m testing all of these cells individually with a multimeter. They aren’t connected to anything yet, just fresh out of the box.
I edited my previous post since using the term “sag” was grossly incorrect and should only be used when describing a circuit under load.
I don’t suspect a factory to trickle charge to a storage state so the voltage will settle quite a bit after charging at 1 amp. If you charge at a much lower amperage the cells will settle much less after removing the charge.
