Hello people!)
How can I mount this gear? This gear fails in a wheel.
You will have to drill through your wheel to attach the gear. I would use a couple of big washers to make the gear stick out more.
Make sure the gear is center when it is drilled into the wheel. I had an issue where it wasn’t perfectly centered and it causes tension issues in the belt if it’s tight.
Or get orangutangs
