@JLabs same issue?
Iāve had the issue as well, on TB 218s and Paris 180s and Caliber 2sā¦itās not uncommon. That why is suggested using sanding cloth, itās litterally 10 seconds worth of work. I typically donāt to all cast trucks.
Pm sentā¦thanks for being on it!
But a file and just grind it down until you get the new one, donāt worry it wonāt break and you will be on the road right away
what grit sand did u use good sir?
I think 300, but Iām not sure. Itās plumber sanding cloth. I guess itās all pretty close.
