However, hub is 33mm wide and is basically as wide as the exposed axle on my truck, which means I can’t secure the nylock nut on the threads. I thought of two possible ways to solve this:
Grind the truck hanger down to expose more axle so the hub can sit further in
Drill a small hole in the side of the axle so that a smaller screw (say m4) can screw into it and hold the wheel in place
Has anyone had this problem, and which way is better to solve it?
How long are the axles on Caliber II’s? I couldn’t find any info aside from one site that listed it as 7.25" for the hanger and 10" total width, which equates to 69.85mm, or 34.925mm per axle, which is not enough.
Forgive me, but a Google search for “ecaliber trucks” doesn’t immediately show me the aforementioned trucks, could you point me in the right direction?
